Attachment 36992
I was originally going to be using these fittings with the metal housing but changed my mind on it and not to mention was dealing with height issues as well.
Attachment 36993
Picked up this 3 way manifold fitting along with the 3/8 barb fittings.
Attachment 36994
If you look closely you can see a somewhat restriction of flow. So I got my Dremel and opened up all three ports.
Attachment 36995
I couldn't find flexible fuel hose that was the 3/8 that I needed so I went ahead and used nylon hose. I found a place on ebay but was like $50 bucks for 1ft I think. Quite pricey for something simple.
Attachment 36996
I used a brake flare tool to grab the line and then get the pump pushed in using a wooden block and a hammer. No heat or boiling water and gets the job done super quick and very air tight sealed.
Attachment 36997
Bought a fuel sender unit on ebay, took it apart and used just the sender unit. (0-90ohm)
Attachment 36998
Attachment 36999
The return hose will feed directly inside fuel bowl to pumps.
Attachment 37000
