So I'm disassembling the stock motor today ... check out all the bearing action probably explains why I had 5 PSI at idle of oil pressure
http://uploads.tapatalk-cdn.com/2016...031e519b25.jpg
Rod caps look like they got changed but not the rods
http://uploads.tapatalk-cdn.com/2016...273a51d0f3.jpg
What's up with the second main Journal back I don't know why it looks so discolored than the others the opposite side in the block looks just fine
http://uploads.tapatalk-cdn.com/2016...b2d11e7aca.jpg
Today I gave the car a little bit of attention I took out the wiring harness did some scrubbing and a little bit of painting
http://uploads.tapatalk-cdn.com/2016...89b7a4296d.jpg
kind of surprising what one can of spray paint will do under the hood
So yesterday I took apart the stock motor .... here is a better look at piston #4 that poped a ring land off
http://uploads.tapatalk-cdn.com/2016...83cd752341.jpg
Drove with that in that condition for about 2 months still ran ok
Looks very nice.
OWNER/ADMIN
Well I got my heater box removed. ... RTV inside to seal it up
http://uploads.tapatalk-cdn.com/2016...bc432c633f.jpg
http://uploads.tapatalk-cdn.com/2016...40d6396472.jpg
Fitment wasn't ideal but I got it to work.
That piston took a beating!
Great job on the engine bay. It looks real good. I wish I would of did mine myself, but I ended up sending it off to get done. It was supposed to be done in a week, but one and a half months later, still waiting...
Painted it today all black
http://uploads.tapatalk-cdn.com/2016...7b82e8a7bf.jpg
Okay it's been awhile since I posted but here are some updates
I found a place who had a mig welder that did aluminum welding and got the heads welded up ... thanks montoya's
http://uploads.tapatalk-cdn.com/2016...acd8e0ea22.jpg
So I got 3 different intakes for small block Chevy and marked where to drill my new holes
http://uploads.tapatalk-cdn.com/2016...16a1244f5a.jpg
http://uploads.tapatalk-cdn.com/2016...8f68424131.jpg
They came out almost perfect ... now it's not a full on machine shop quality but it will work perfectly.
http://uploads.tapatalk-cdn.com/2016...1c8c168531.jpg
http://uploads.tapatalk-cdn.com/2016...fdb8f9abbc.jpg
http://uploads.tapatalk-cdn.com/2016...a1cf044112.jpg
http://uploads.tapatalk-cdn.com/2016...4532f46fac.jpg
So the outer bolts are the stock bolt angle and the closer is the ones I re drilled and tapped
http://uploads.tapatalk-cdn.com/2016...2c0054551a.jpg
http://uploads.tapatalk-cdn.com/2016...3462b81697.jpg
I think I am doing good.
Here is a video of me drilling them
https://youtu.be/Rn1dww7v_oQ
Well I take 2 steps forward and 3 steps back ... so one of my valve cover bolts had some messed up threads and since I have been tapping stuff all afternoon I thought it would be a good time to run a tap and clean up the threads on it ... I got it bottomed out and started backing it out after a few turns it caught some threads and got stuck ... and after several minutes of being careful no to snap it off ......
http://uploads.tapatalk-cdn.com/2016...eb6950fea9.jpg
http://uploads.tapatalk-cdn.com/2016...914095e256.jpg
Fuck me .... how am I supposed to drill out hardened steel?
Carbide steel bit and pray?
Or, if you are brave, knock down the perch that has the threads in it so you can grab whats left of the tap with a vise grip?
