Reason for edit. Lol
Sent from my A621BL using Tapatalk
yew delawarians lol
there finished and level ground. 1) I like the look now 2) I need to roll quarter lips due to the BMW offset the rear passenger rubs the lip over bumps with a full tank and a passenger 3) my used starter has a dead spot. go figure. if it's not one thing it's another.https://uploads.tapatalk-cdn.com/201...06964fa9f4.jpghttps://uploads.tapatalk-cdn.com/201...21933e0c50.jpg
Looks good I was going to say didn't you lower it. But you can see that fills the opening nicely
on the phone using Tapatalk
Any bump steer?
I dont live to work.I work to live
waht? car isn't low enough to really be affected by any actual bumpsteer. my bird was much lower and was just starting to exhibit bump steer which I corrected with a baer Heim joint kit. this car will get a correction kit when I lower it more, and when I set my alignment for rr
I guess gen 4 is deferent. My gen 3 had the pro kit and bump steer real bad. But I think it had a steering box and not a rack .
yes, 3rd gens have a steering box and 4 link steering. they exhibit bump steer with even sagged stock springs.
I will be running -1.3-1.5 camber, a little toe, and all the caster I can get up front with stock arms. wish I could afford umi arms again
That shoud tighten it up a bit. seems the stock setting is a bit... to wonder a bit
