LOL.... Fair enough:)
I was just doing the right thing.
Im confused on ur question about air... If u blew off any coupling...wouldnt u go FAT rather than lean? I mean it would be between the blower and the TB where ever it would be...and that would kill boost...and no matter how much air the tb pulls from fresh air... It would not be as much as boosted air.... or am i misunderstanding
Co-Owner/Admin @ LTXtech.com
No you're right. I was just thinking that after you lift off the throttle the ecm might command an idle cell in the fuel map and go lean, based off its thinking that little to no air is coming in. But in the end, the map sensor should save you there.
Yea. Maybe its not as bad as I think after all.
This guy right here...
http://www.summitracing.com/parts/sum-470450
Unless I can find a good used cowl hood on craigslist.
Yep. I looked at going with a small, off centered hump (think 80's turbo trans am) just big enough to cover it but I though it wouldn't look right.
Sounds like your close enough to start thinking about getting in some track time :finger:
