Great !!! Look fwd to meetin u whether racin or not.
And as far as ur motor pics... i never wouldve thought of blacking out so much of it. It does look sinister!
Same. I'm hoping to hit the dyno day too. I have to double check the date since it's escaping me now.
The plan was black and polished/brushed accents. Everything in the bay is black sans the accessory bracket, charge pipe, fuel rails, throttle body and pcm cover.
I had the canton mail boxes on the engine before which gave it a bit more "bling". While they looked cool, they were huge and annoying to work around. I had to angle the two rear passenger coils to avoid them hitting the heater box.
The lt4 valve covers are awesome in my opinion. The studs are a great design feature and they fit really well. I have a MBA dress up kit sitting in the box but the coil pack brackets would cover most of the pieces.
Awwwwwwwww yeaaa!!!!
Way to go BLS, good stuff indeed!
Dyno day is Sat on Easter weekend....
Received a revised tune from my tuner to lean out the idle a bit. Have some new 02s to install and another for the wideband. Hopefully get that done and give it some more run time in over the weekend.
Very clean. Your latest build appears to be fairly close to my mine...I'm interested in seeing your numbers through the manual. What pulley size are you running?
