Attachment 30032
Still waiting for my beat down
Attachment 30032
That just made my day race gas queen :wheelchair:
Your intimidated by the stance....aren't you
Yes father :surrender:
@NightTrain66
Hey lloyd is it OK to have a hair bit of lateral movement on the Rocker when it's on the base ? There at zero lash with a quarter turn ...
Seems like these guides are a little worn? Idk
it seems like the valve is moving in the guide or the rocker is moving across the valve tip?
The rocker can move a lil side to side (as much as the travel of PR in guide plate will allow) but it "looks like" the rockers are notcentered on the valves in these pics.
What guide plates and rockers are you using?
Thos are NSA rockers, correct?
Lloyd
There comp guide plates and 1.6 crane golds.
yes nsa rockers
Only looks like a couple are not centered ... I haven't lashed them in like 3.5 years ... think I should re do them? . @NightTrain66
There's only 2 that look out of whack.
so. got my dedicated done an d put in car and wired. @noice. Pump seems to hum along good! Thanks again, which one of the twins is this?
Also got my pump all done .... just need to put my custom valve covers on and re go to track
Just waiting on the wideband from Chris.
Have you checked the pressure yet?
Nope gonna get a gauge on it Tuesday and check it.
