Originally Posted by
Injuneer
Is DFCO set to reactivate the injectors at a high enough RPM, and prevent stall? As you are well aware, I'm not a tuner, just like to look at the data. Just throwing out random thoughts. DFCO results in engine braking on decel, at least (I believe) with the stock 4L60E. But with the full manual valve body in the TH400 there is no engine braking.
And I understand the age of the brakes has nothing to do with the vacuum booster, but just an alert that in their ancient condition (glazed? warped?) they may take a bit heavier foot to be effective, specially when you pull the car down from those future 130+ MPH trap speeds :D
