I'll be surprised if he can even get it up lmao :) hahahahaha
Smoke tires not drugs
well went to the track and sprayed a 225 shot ... yeah still stock tune and timing and the car got hurt but is still alive ... i was going to pull a plug make a short hit kill it and read the plug to dial in my fuel jet .... my wide band said i was running rich ... so i pulled the plug wire and the tools i had borrowed were the wrong size .... so i took the back and forgot to put the plug wire back on .... so i made a test hit and the car didnt seem right ... so i limped it home cause it had a bad miss and made a few bad sounds .... well on the drive home i stopped and remembered the wire put it back on and it ran better but still had a slight miss. well today i found out why.
http://images.tapatalk-cdn.com/15/06...5eea3a468a.jpg
http://images.tapatalk-cdn.com/15/06...6cdfe75758.jpg
http://images.tapatalk-cdn.com/15/06...c2316e7da9.jpg
http://images.tapatalk-cdn.com/15/06...04968d6b47.jpg
So apparently I popped a ring land on cylinder number 4 ... I'm not able to get my borescope turned to see up and look at the valves however I'm sure they're damaged so my car was only running on 6 cylinders but I still managed to go 13.1 at 96 miles an hour coasting after the 880 mark ... The car proceeded to drive home 42 miles on 6 cylinders ... Needless to say no more Nitrous for this motor I'm probably just going to take the grounding strap on that spark plug regap it put it back in ... That way if I need to move the car I can but now I'm going to focus on building the motor I have on the engine stand and get it finished.
Damn that sucks
Did you at least get the wheels up?
Almost ... I have a spark plug wire unplug during of picture and the ring land issue ... So essentially 6 cylinders
http://images.tapatalk-cdn.com/15/06...4484ce652c.jpg
Damn that sucks. Grab you another short block swap stuff over and rock and roll.
Probably wouldn't hurt to pull some timing this time lol
