:thumbsup:
:thumbsup:
Where u boost guys referencing ur Hobbs switch from? @shownomercy @Fastbird @popo8 @blackbirdws6
Intake manifold. I have a vacuum block for the various things.
McMaster Carr gots what you need. Figure out what you want to see vacuum/boost and get the right block to do the job. SNM is the plumbing guru.
I used a fuel line fitting that fit perfectly into the brake booster hose. then the hobbs switch simply screwed into it.
@Ltconvert there ya go
