Your lonnies double pumper would have to be way modified to fit, completely different style tank. The impala is a b body that was around for years, tank isnt even baffled. Its an old school rectangular tank.
Also no, your camaro procharger bracket and accessory bracket are totally different. The motor on the impala actually sits further down and back than the fbody. Hence bbody balancer/accessory bracket pushes accessories out further, and theres those pesky things called a frame rail/steering box on the driver side that wont let the blower sit down that low. It will basically be up where the abs block is currently on the impala, which would have to either be moved or deleted.
This is how high up the supercharger has to be to clear the steering box/frame rail/steering linkage
http://uploads.tapatalk-cdn.com/2016...daccf5f9f8.jpg
