Checked the knock sensor wire, it wasn't burnt. Went through the entire car, and could not hear any knocking or ticking, minus the valve train. I re torqued the KS to 14 lbs, and it was just as bad, if not worse (maybe its worse because I was in a garage and it was louder?)
I tried the trick to cover the ear holes of the knock module on the PCM, (after I re-torqued the knock sensor) and it was the worst of all. It basically sat at 5 degrees from when I started until I shut it off.
Would that be a sign of a bad knock sensor? I have videos of it running, and I hear no knocking (but my hearing is also bad). @LDM @gmpowered @SSlowBoat
the plastic piece on the sensor is wobbly, as well, I'm going to replace it anyways, they aren't very expensive.
