i asked so many people about that!!!!!!!!!!omg. so will a 95 still work with my non vented opti?
my best friend put his 94 computer in his 96 formy and everything worked. so i assumed it would be for all of them.
If I understand it correctly....
1993 gen 1 opti,
1994 gen 1 opti. OBD1 port, OBD1 computer OBD1 harness (wire routing)
1995 gen 2 opti. OBD2 port, OBD1 computer, modified wiring for harness or for port (unsure).
1996 gen 2 opti. OBD2 port, OBD2 computer, OBD2 harness.
from what ive been researching the a 96 harness will work as long as the knock sensor matches the computer.
I think your right but its the other way around. California 95's got the obd 1 port. Every 95 I've seen had the obd 2 port
Ok, thats something I was not aware of...
Still learning here as well....
Sean, do you agree without repining, or the proper harness, odds are he cooked the computer?
OP do your fans turn on and run steady when you key on? Thats what my car did every time we cooked a computer.
Or maybe it was the California 95's actually got obd2...
With this new found info I'd try to get a correct computer for the car. I don't know about all 95's, but mine is a Cali car and has OBD1 with an OBD2 port.
ill check out the fans first thing after work tomorrow. what I'm confused on is if people have 96 cars and use 94 pcms to go ob1 how come every write up i see says only switch the knock sensor. i havent seen a re pinning one yet. thanks for all the help btw guys
Posted a video on the fb page for ltxtech but Idk how to put it on here
