ok and im assuming i need the one for the comp.???
since the guage is working fine.
That is what they have been trying to tell you. The sensor is not the same part # as the one in the head.
http://shbox.com/1/temp_sensor1.jpg
Have you done any actual troubleshooting?
http://shbox.com/1/4th_gen_tech2.html#cooling
ok so all the wiring looks good, nothing is burned or broke. i replaced the sensor and that didnt work. fuse was replaced even though it looked ok, relays are working also.
so now i think im just going to pull the stock fans and run an after market one, or bypass the comp and run fans to a switch
