pull the plug wire off and grab it while a friend cranks the car...
:jest: sorry, had to. please don't anyone do that. i'm not responsible if you do
I have a problem from 4.5+RPMs and can't figure it out.
There is no one else close by with an LT1 that I borrow a coil from to test.
My car did the same thing recently.My cars check engine light came in and it said it was the evap solenoid. I changed it and the problem went away.
^hmmm, I got a check engine for code P1441 I belive. Something for a non purge.
I had my Evap taken out and it should of been tuned out of the computer last time I was at the dyno? But I guess he deleted the wrong code.
Does anyone know if the P1441 non purge noid cause rpms to break up at 4.5 rpms?
