Oh really now? would have never guessed an AI package running a 20.
But I knew what you were saying :frustrated:
RamairTA. 2000 is a lot for a stock casting head. I have a fraction of that into my heads cuz I had a local guy port em who I know is just as good as le. He's just not as main strean so charges accordingly. I do agree Good parts and work cost $ but if you shop around you find just as good for a buck less.
Hell im not one to skimp. I have a callies 383 dragon slayer crank , je custom blower pistons , supercharged ,etc...
It pays to shop around. And with anything if you have good results with a certain brand of corse your gonna support em.
Sent from my Droid using Tapatalk
It doesnt hurt my feelings at all but to say "LE is for the more budget-oriented owner who is easily pleased" is obviously just YOUR biased opinion. Lloyd ports heads for serious racers as well as "easily pleased" budget oriented owners.
I can't count how many times I've seen someone suggest AI to someone, only to have them say "well I don't need all of that for the cost, the LE1 heads will work fine for me." I'm sure with enough searching through the forums you'll find the same thing, so this isn't my opinion, it's really fact.
I know Lloyd ports for some of the big guys, but from what I have seen those are mostly aftermarket castings. On occasion his stock ported castings make their way onto a race car build, but that happens far more infrequently than AI.
ook well my goal is 400 hp and i wanted 30lb injectors because i dont have injectors anymore and i heard that was a good size with the cam that i have i also work at an auto machine shop so ill be doing all the work myself and as far as the low end goes i turned the crank and im getting it balanced thats all ive done soo far
I just wanna know if I am the only male that cringes at the term NUT SWINGER... it sounds so painfull and I can only imagine it would stretch a sack to the ground...... then your forced to wear tighty whities because if you dont the bag will hang down and drag as you walk... brush burning and cutting the skin, which could lead to infections etc..... I mean is it just me that thinks like this....
JUST HAPPEN TO HAVE A VISUAL
http://i104.photobucket.com/albums/m...utswingers.gif
