Get rid of abs, makes engine bay much cleaner.
Come flare brake lines because I don't know how to
Dumb question. Flywheel replacement? Or just get it machined?
http://uploads.tapatalk-cdn.com/2016...1c2ebf7f0e.jpg
Cheater cheater Daniel @SJx408
I might just get a power torque flywheel from work. Those should be balanced already right?
Pick boogers
Its a lesson we all have learned at some point.
You guys are bullying a kid trying to learn
And your point is?
I have no point
I'm stupid duh
Fixed the brake line, thank you guys!
Put an hour into the car draining coolant, fixing that line, pulling fans and almost radiator.
http://uploads.tapatalk-cdn.com/2016...9b1ff268d1.jpg
http://uploads.tapatalk-cdn.com/2016...57aaff10e7.jpg
Got 2 hours of sleep last night and started dozing off.
Noice
Thanks bruh!
Ok, just so I don't fuck up anything, I'm going to ask.
There is a timing mark on the crank hub that I have to align with the mark on the timing cover correct? When that lines up, the timing chain should be line up as well right? And then when I reassemble everything, I assemble with the timing marks in the same place I removed them right?
Future thank you.
Get it apart already.
@Dan what exhaust you going with bud? I don't think I saw the set up listed
You should see the color my Springs are gonna be[emoji14]
Neochrome cause ricecar @Dan
@SJx408 nooope. I should be getting them coated in the next few days
What would happen if I sprayed a 100 shot?
It would make more horsepower in theory.
If you do want just a 100 shot a single nozzle right after the maf will work perfect and be the cheapest. Nitrous outlet plate the best plate for an oem intake
It'll give you more powers, and be fun.
You can go up to a 200 shot without tuning for it too ;) hahahahaha
Hahaha ha running! That'll never happen. Heads coming in tomorrow. Been sick lately
Least it wasn't Denial
Does that say "D ANAL D" ???
Dan D. Would have sufficed but D ANAL D is hilarious!
God damn it you guys lol. At least it'll go good with the pink timing cover lol
Lol...
OWNER/ADMIN
