Are u seeing just head gasket issues or anything else?
OWNER/ADMIN
OWNER/ADMIN
Ill take some creamer with my.coffee :tt2:
Fingers crossed it ate a gasket. Easy fix, unicorn will be back on the streets of nj tearing up civics!
It def ate a gasket, should not have reused em. Lesson learned.
Well then thats not bad. Do u need to resurface the heads?
OWNER/ADMIN
I just wondered if that was ur issue from the other time, and not necessarily the reuse of the gaskets.
OWNER/ADMIN
Say what?
Didnt u pop a head gasket before... last season, or was that someone else?
Im wondering if ur head or block surface is not true and maybe that is why ur getting failure since I thought this is not the first time it happened.
OWNER/ADMIN
Nah, last season I snapped the oil pump DS.
Part out yet??????
https://scontent-lga3-1.xx.fbcdn.net...de&oe=570DBB54
Guess I should go pull the heads finally, over under on them being warped to all hell?
Im gonna guess they need re surfacing at least.
OWNER/ADMIN
Lol... is scapped the same as resurfaced?
OWNER/ADMIN
The trash bin knows not the difference.
Just get her ready so u can work the bugs out soon as the snow melts...
OWNER/ADMIN
Snow?
It was mid 50s all day, supposed to hit 70 next week.
Well, got the driver side head off today, and the pax side is loose just gotta yank the alt bracket tmmr. Then steam clean heads this week at work and check em for straightness.
Got this for xmas
https://scontent-lga3-1.xx.fbcdn.net...e2&oe=5720270E
Should shave a few pounds going from steel to aluminum and finally ditch the MAF.
Movin right along... now check the heads and the deck for straightness
OWNER/ADMIN
Thats this week, with my luck it will all get buttoned up and finally decide to be winter :lol:
I thought you couldn't pull heads with studs??? You must be a magician!
Where's my blue bullet sticker u were going to send me?
Spent the morning thankfully not hungover and got the heads torqued back on. @blackbirdws6 was kind enough to swing by with fancy torque gadgets and we got em done.
Since no one cares about heads being on, here is a teaser from the man himself, @NightTrain66
https://scontent-lga3-1.xx.fbcdn.net...56&oe=571C28B9
Getting close!
Science is fun! Intake looks great. I'm really curious to see what this picks up.
I am interested in seeing how much the car gains also.
Lloyd
Should I be worried about the elbow being smaller than the intake now Lloyd?
Just put the big elbow on it, you have a cowl
Fucking got cold but, this is LT1 life
https://scontent-lga3-1.xx.fbcdn.net...55&oe=570839BA
Nailed it @NightTrain66, awesome port work and very thankful of the help
Maybe just maybe you stand a chance now :boat:
