they make gold plastidip, it wouldn't be hard to try it out and see how you like it before dropping it off at the paint shop.
Im bein told the trans...torque converter...a rear main seal...the control arms and some misc items will be swapped out today.
LTXtech.com is my Drug...
Trans is out... new rear main seal and aluminum crank sleeve will be in 2moro. Then new trans...tc...and cooler will be installed.
Crank end sleeve came..installed. oil pan gone over...tight. wrong rear main seal sent...waiting...then install new CPT trans...
Attachment 29145
Attachment 29146
http://img.tapatalk.com/d/14/06/13/depemupu.jpg
Its called a speedy sleeve n its the same as the sleeve repair people do on balancers or pinion yokes it gives the seal a new surface to ride against. You can't see it but thats where it goes
I guess thats where that gold ceta pic came from...I really like it. Alot.
