Hawks has a hatch release switch for $13. Says it’s for 93-02 Camaro and Firebird.
https://www.hawksmotorsports.com/93-...n-switch-used/
My 94 and 96 Camaro's have the button in the glovebox but my 97 has it near the hood release.
I think I have the panel/button, I can check.
Update- I have the panel but button is MIA
thanks to a good friend @Fastbird i have a fix for the redneck engineered fuel return line thats broke under hood. found some about to break grounds on the drivers side cylinder head, along with an accell coil. luckily i have a coil laying around (good thing we are lt1 parts hoarders) so that will get swapped this weekend, see if the idle cleans up after the rad swap and new fuel lines.
shes in the garage and work begins. some pics of the car and "handy mechanic work" the p.o. "mekanik" did. ugh
allegedly the "low coolant" light "was just always on, coolant was never low". the cracks in the rad end tank determined that was a lie. https://uploads.tapatalk-cdn.com/202...6df51fb2fa.jpghttps://uploads.tapatalk-cdn.com/202...5b4013775e.jpghttps://uploads.tapatalk-cdn.com/202...b7be6e941b.jpghttps://uploads.tapatalk-cdn.com/202...68a8ff31f6.jpghttps://uploads.tapatalk-cdn.com/202...af08b2482f.jpg
crank pulley and opti next, then stock manifolds/y pipe.
who has some longtube headers laying around?https://uploads.tapatalk-cdn.com/202...519bde98f5.jpg
I'm losing track of your projects, don't you have a built LT1 in the stable that you can just swap in? Speed Engineering 1 7/8 for the win
