what ls1 shaft where you talking about ?
I'm wanting to put in an LS1 steering shaft (the one that goes from the rack to the main column) to replace the shitty rag joint shaft that came in LT1 cars. It will fit but you have to bust out the spline, reclock it 90 degrees and weld the spline back into place. I don't have the tools to do this, so I was trying to find someone that did or could do it for me.
welcome, car looks beautiful. always nice to see a clean LT1 car
They do look goofy on the camaros, I would defiantly hold on to it because those things are EXPENSIVE and hard to find.
If I was going to do heads and wanted a milder setup I would do the LE2 heads but run a milder le1 cam or just a cam with less overlap because you WILL want more power later.
I already sold it. I got like $150 for it or something.
About the heads, I'm not completely sure yet. Come this fall, i'll call LE and see what they have to say with my plans for the car and it having 135k miles, etc. Any cam that doesn't need to spin too high and makes good low end torque would probably be good enough for me.
Welcome!
Exceptionally clean car. I really like the clean, "stock" look on the SS's. Then there's the killer red!
Good luck with it!
