holley 650 double pumper no choke and manual secondaries
10lbs is quite a bit of pressure for a carb, I dont know if any carbs are built so the needle and seat can work with that pressure, but a regular 650 DP wont..
https://www.summitracing.com/parts/qft-30-900
a guy named Joshua Canady told me he is using the stock fuel lines and a 255LPH fuel pump ... any one ever heard of this company?
Quickfuel? Yes. Nothing wrong with that. Sounds like you have everything in order. Run it
Not sarcasm. You confirmed the only issue I seen with running the stock return line with a low pressure setup. If someone has done it successfully already, run it
did more looking and reading and i want to stick to areomotive brand
But what one
http://uploads.tapatalk-cdn.com/2016...ff37f375fa.jpg
http://uploads.tapatalk-cdn.com/2016...914fd34ebf.jpg
