I got it figured out using these steps from tunercat.
1. First uninstall the program if you have already installed it.
2. Log on to your PC as an administrator.
3. If you haven't already, download the setup program for the latest version
of the WinFlash program from the 'Downloads' page on our web site at
www.tunercat.com/software/winflash/flash_setup.exe and save it to your
Desktop.
4. Before running the setup program right click on it. Select 'Properties'
from the pop-up menu and then click the 'Compatibility' tab. On the
Compatibility screen click on the 'Run the program in compatibility mode,
select the default Windows XP SP2 (or SP3), check the 'Run as administrator'
box, click on the 'Apply' button and then click on the 'OK' button.
5. Now double click on the setup program to install the WinFlash program and
follow the on-screen instruction to complete the installation.
6. After completing the installation you'll also need to set the WinFlash
program itself to run in compatibility mode. To do so, right click on the
WinFlash icon on your Desktop, Select 'Properties' from the pop-up menu and
then click the 'Compatibility' tab. On the Compatibility screen click on the
'Run the program in compatibility mode, select the default Windows XP SP2
(or SP3), check the 'Run as administrator' box, click on the 'Apply' button
