Originally Posted by
myltwon
Honestly if it's hard to start when warm, I would look at the fuel pump. Not sure if that's what's causing your drain but that's always been a sign for me that a fuel pump is about to crap the bed. Might want to even check the fuel pump relay as well, I've seen enough cars have issues with it and that could be leading to a drain and failing fuel pump symptoms. A decent test is to hook up a fuel pressure gauge and prime the pump while wiggling the relay, also check for any signs of burn plastic/wires around it.
