Mine is gone, 99ZRinehart's is gone. No difference in the way I drive but I don't dive turns and shit anymore. When I bought my WS6 the SB endlink was broken and never noticed it till I swapped wheels for inspection. It has a pretty UMI peice now.
weight is not the problem mine is a hollow 34mm,do you guys have solid 1's.
removal is a old school drag trick to help weight transfer like putting you battery in the rear.
have you moved the battery?
only time i could tell mine was off was when you try to turn quickly. when that happens you turn the wheel then a few seconds latter the car catches up lol
but i always drove around on skinnies too.
Removed mine and still handles decent to me. Running all poly bushings in the rear. (Think that helps the handling) also running Skinnies up front. Like someone else mentioned, I don't take hard corners.
