Originally Posted by
dawdaw
Well while building the car for STRICTLY for the track, highly consider the fuel and what your willing to spend. Every fuel has advantages disadvantages.
On a NA build lean towards a oxygenated fuel. Q16 makes good power but has MTBE in it and is harsh big time on fuel systems, E85 is oxygenated and makes good power, is dirt cheap, but has to be drained every couple months if it sits cause it attracts moisture and the moisture will eat fuel systems.
If you're just looking at a mild build in the 12ish region for static compression pump gas 93 will work, your cooling system, TUNING, and how much cylinder pressure you make based off the split in the cam, cam timing, ring selection, etc. I ran 93 on a 12.9 almost 13:1 motor but I switched to E85 and am looking forward to.hopefully some good results, or at least my tuner thinks so lol.
