We're street tuning it so I can't confirm with actual numbers, but it felt like a monster at 12.9-13.0 vs mid 12's. Night and day difference when we leaned it out.
How much timing you running?
I'll have to get the tune in front of me, my friend has the tuning laptop at the moment. It's aggressive, but doesn't knock at all. What kind of timing do these cams like? I assume that as long as it's not knocking, I'm not going too far?
I'll get a copy and post it.
Car was running 34-37* at WOT, 12.7-13.0 AFR
I took the car out for a bit yesterday in the early morning when it was nice and cool, and the AFR was as low as 12.6 at times. I think I might need to do some more MAF tweaking and dial it in a bit. I'll make some changes this weekend and get a tune and updated scan posted. Thanks everyone for the feedback.
you tune to what the car wants, every set up being the same are different, looser tolerances in the motor, factory balancing, carbon build up ect. I have had two identical cars, basically the same mileage, same cams ect, put them on the dyno and one would like a richer A/F with more timing and the other Leaner with less timing, One made 20 more RWHP. Back in the day Chris Bennight was the LT1 Guru, he had a cam, bolt on only, M6 with a lot of gear and ran high 10's, Very aggressive tune, 39* total timing up top. Again, I tune to what the car wants, of course check your plugs for timing marks, heat ect..
isnt factory like 5750 or something like that.
