TF says an FR5 ngk is what my heads use. Its a 3/4" reach, projected tip, gasketed plug, 5 heat range.
I'm running a 19mm reach, non projected tip, gasketed plug, 6 heat range.
I switched from a br6es to a br6es-11 only difference is one is 3/4" reach, other is 19mm. The br6es is hard to get locally. Both have same issue.
Sent from my SCH-I535 using Tapatalk 4 Beta
