Originally Posted by
Fire67
To the O.P.
I am running a crankcase evac on my car. It pulls vacum throughout the entire rpm range. Including idle. Dont get the Mr Gasket kit, as you need the tubes with the cut in them like the ones from moroso. If installed correctly they will work.
The only thing I did as far as my WB O2 was to put the tubes and checkvalves downstream of the 02 sensor. With the FAST system, I just put the sensor in one of my collectors, and the tubes about 8" past the 02 bungs in the pipe that joins to each header. Works great as long as you dont go too far back with the tubes.
Almost forgot... These do not work very well with mufflers. They work good with my straight through Dynomax bullet, but anything less than a 'straight through' muffler will introduce backpressure. Backpressure will slow the velocity enough to stop the venturi effect from creating a vacuum.
