No one will care, its a stock replacement part that gets you no added bonus over others.
Although, rules state you can run NSA rockers and guideplates but no mention of new PR cause of the added length needed. IE, not pure "Stock" anymore.
LT1 cars are old, and most have high miles and need parts replaced. The way I see it, as long as the part you replace it with does NOT pose a performance advantage, then go ahead and run it. Now if you go and get some exotic pushrod that weighs way less, you might be in trouble. I'm sure the rules makers will chime in but a hardened pushrod simply helps with longevity, it doesn't add power.
What material and wall thickness are the pushrods you bought? An argument can be made that a stiffer pushrod would help with valve train stability and help squeeze out a little more power. I agree that if it's just a normal mild steel hardened pushrod it shouldnt be an issue, however this is one of the most restricted classes that the shootout has and it has to be looked at pretty closely. 5 to 10 horsepower can be the difference between a W or an L.
I haven't purchased any rods yet. But if or when I do, they would likely be 7.2inch chromoly with .080inch wall thickness.
I completely understand that this may give an advantage in some cases that's why I wanted to ask. I know the shootout is more about having fun and that's why I want to go next year. If this is something that won't be allowed I am totally fine with replacing with steel gm performance ones.
Well it's not that they're not allowed, it's just that push rods are not clearly listed in the rules as to what guidelines they have to meet except for the general internal engine modifications of being similar weight size strength ETC . The rules do allow for roller rockers, even non self-aligning ones which would require guide plates which would require hardened pushrods. I think it's just something we'll have to clarify in the wording of the rules
