the seal from a 5 quart jug of oil sounds like what youre describing. put it back together and run it
here is the piece next to the pin i found too. its not an oil seal from a bottle, its thicker than that.
Attachment 38993
got a few hours today to do a couple things; got the turbo oil drain bung booger welded to the pan and got the ls1 front spindles and brake caliper painted. broke the bleed screw off in the other caliper so need to drill that out or get a new caliper and paint that to match
Attachment 38994
Attachment 38995
so as part of all this i am also deleting the ABS module (already removed the module from the engine bay) to make more room for the BOV and to clean up the engine bay. from what i am reading there is a kit from SJM but it doesn't seem to be that great of a kit according to this thread (http://www.ltxtech.com/forums/showth...ght=abs+delete) so i am trying to piece together everything that i will need separately. from what i gather i can hook up the rear brake line directly to the master (i have a 3 channel car) and use a proportioning valve for the front with a split after to run the two front lines, is that correct or do i need a proportioning valve for both the front and back? not looking to do line lock or anything at this time just trying to keep it simple. looking for some insight from people who have done this
You need a proportioning valve for the REAR brakes, not the front. so it would be rear line from master---->prop valve--->rear brakes. Front just gets a tee and goes to both front brakes. you want full braking to the front (brakes that do most of the braking) and less to the rear, since when you hit the brakes the rear weight transfers forward. Otherwise you will lock up the rear brakes (which is really no fun, especially when going towards a deer then a tree then a house then a truck, had my prop valve improperly adjusted and still locked up rears)
if you are making your own brake lines, save the money and buy the Summit prop valve.
https://www.summitracing.com/parts/sum-g3905
And, do yourself a favor... buy & install a line lock solenoid.
https://www.summitracing.com/parts/s...iABEgIUifD_BwE
Even if you don't wire it up, you will want it when the car is setup and you want to do rowdy burnouts
eh, @Ltconvert has a line lock thats never been wired in his, he makes enough to do rowdy burnouts without it lol
what spark plugs would you guys suggest i run? currently have TR6's in the car and figure this will be a good time to throw some new ones in while the manifolds and subframe are out of the car. also, where are you guys getting 80lb injectors from? are they the same injectors that would fin an LS or are the LT specific? i think i got the 36lb-ers off ebay that are in the car now but not positive. got some stuff done on the car over the weekend which i will update with pictures later but trying to get these on order today so i can have them by the weekend
I'd recommend either a NGK BR6EF or a BR7EF depending on how far you plant to push it (BR7's are colder, my T/A would foul them QUICK).
I run TR6's and probably are at the limit of what the plug is good for. ~15psi of boost.
If you don't want to pass that level, run TR6s and don't have to change em that often.
