Originally Posted by
94ndta
Worked on it some more today. First thing I did was inspect the flywheel for cracks, got some new tq converter bolts, TQd them properly (old ones seemed fine) removed 1 fan that I thought the water pump might be hitting, dynamatted the knock sensor, torqued it to 14 ft lbs, checked over everything again for anything that could rattle. Still the same issue.
I took a stethoscope to the motor and exhaust again to see if I could hear anything, nothing it of the ordinary.
I can tap on he exhaust and have it register knock, more so on the passenger side of the engine than the driver. I'm going to try to dynamat over the knock module for diagnostic purposes, simply to see if only one of them is picking up the knock.
If that doesn't work, I will maybe try another knock module, knock sensor (even though it tested fine) and then last resort maybe a new PCM.
I'm 100% certain it is false at this point, really good A/F when dynoed, does it with race gas, does it when not under load.
This is getting really old.
