http://uploads.tapatalk-cdn.com/2016...f67652f209.jpghttp://uploads.tapatalk-cdn.com/2016...281f61a42c.jpghttp://uploads.tapatalk-cdn.com/2016...7dcd47d323.jpg
Found brand new king si stock sized main bearings in another block sitting in garage, score!!!
http://uploads.tapatalk-cdn.com/2016...bba97ce4b7.jpghttp://uploads.tapatalk-cdn.com/2016...b21fb51f4e.jpg
Measured crank. Looks like std size rod bearings will be good. Main bearings everything mics within spec for production except #5 which is 2.4476". Anyone got a bearing size suggestion for mains?
I'd go ~0.0022-25" on everything and spin the crap out of it. Any plans for spray?
So std size bearings then and then check clearances? I'm having a hard time finding bearing id's online to see what I needhttp://uploads.tapatalk-cdn.com/2016...b0d877f9b7.jpg
Are you doing anything with the mains, or leaving it stock caps/bolts? (sorry if its already mentioned)
Ordered king main/rod bearings and mahle stock replacement rings last night.
