Is it because of our smaller size that we can not just copy the classes at other events?
We are talking about a date change not location change correct.
Agreed.
Also mod na is a full tilt radical na clas, why limit ccylinder head selection to a 23 degree set up?
It should be lt1 block , any fuel, head, pcm u want, any suspension allowed.
Also mpa should not see a hit for afterkmarke . Ecu
Also a single 88mm will walk circles around a single stage n20 system in mod . I feel the f1a is a suitable blower for that class
Also direct ports should be allowed in.espa just limit them to a certain hp rating so.theres no unfair advantage over a nozzle or plate
My .01 cents
No wheel sizes are not a big deal can eyeball those. If anyone uses a direct port it takes all of about 10 secs tp crack an 11mm nut off and check.a jet
So you're basically saying make mod na an outlaw class, minus power adders? What about the mod pa guys? In the past the rules for pa vs na in mod and extreme street are mirrored, give or take the power adder. This was done for the nitrous guys so they could run both classes if wanted. By making a change to one and not the other could potentially keep a guy from being able to do this.
No im saying free up all the stupid restrictions on mod na. Its supposed to be a full balls to.the wall.all motor class .
No one with an naturally aspirated combo is gonna run outlaw.
Or maybe i interpreted what you said wrong.
Yea, basically you want an na outlaw class. Run what you bring as long as it doesn't have a power adder, correct?
Pretty much.
