Originally Posted by
firebird_1995
No it only requires one sensor. It also operates the injectors in batch fire, like the 93. I've got a few datalogs and I've watched for something to jump out at me. For the most part it seems good. After startup the iac brings down the idle to around 1200, ignition advance stays constant, it will sit at about 11-12:1 running fine then when closed loop starts it begins to auto adjust the AFR to dial in the actual to requested. After it leans it out to 13-14:1 it starts popping. Kind of lightly at first, ending with firey explosions. I have tried different plugs, wires, checked for header leaks, changed the bad msd opti, ran with stock injectors and throttle body. The only thing left is the opti or the dfi
