Well dont change mechanical stuff up after he tuned it to be right and safe...
OWNER/ADMIN
Okay...
OWNER/ADMIN
It's home, Marcel explained that he couldn't get the converter to lock at all, dno why, thought it had lock up. Osie stated it felt a little surgier than before until it gets into closed loop. But it feels stronger all around. Marcel again explained he knows its making more, and apologized for the dyno not showing it. It only made 6.5 psi, Afr went down to 11 most of run then towards 6500 it was 11.7. He also explained now any changes can be made email. I screwed up on the impeller math, plus now the motor is built for boost, so we lost some from stock c.I. build. That's OK, they make bigger crank pulleys. He said it's definitely in the 10's with a tire and driver mod
Sent from my MotoE2(4G-LTE) using Tapatalk
Get that puppy pullied and see what it does!
Ordered
So what do i win for voting wont make it
