95 underhood fuse box has #9 & #10 for injectors. One per bank. Pink wires. COnnector C100. The connector on the passenger strut tower.
Pins A & K should have 12V switched ignition power.
96 underhood is only showing #9 on Pin A. This wire splits and powers all the injectors.
To me that means, the C100 connector was on the car, making it a 96, so that pink wire at Pin A will then need to feed BOTH Pins A & K on the '95 engine harness side.
Make sense?
