didn't you y block yours and return them into a y back into the trans? had any good amount of street duty to see temps?
are you dumping the exhaust right at the k member?
I was, aimed it by accident at the trans, so the trans temp sender I think got some external heat projected at it.
I have a hose barb 11x10x3/4" and a -6an 10x7x1.5" here. Opinions?
Go fittings, hose barb and hose clamp is rigged IMO.
MVB means high line pressures, don't cheap out.
With a manual valve body 4l80 can you run some form of aftermarket shifter? or using a stock one?
Yea, any gate/rachet shifter will work as long as you get it setup for a 4 speed.
Gotcha. Think the an cooler is big enough?
