Like 6-7000 or so I think :( I only got them last August.
Sent from my screamin chicken pimped out SGSII
Off to workmans comp court.... Lets see who the Judge sides with.
And def not enough miles peter...
Get in the habit of an alighment every time u do tires... For handlong my fronts are purposly set leaning in at the top...
Larry (Popo8) Co-owner
LTXtech.com
good luck in court sir
I just can't figure out why all of a sudden it ate through them like this. I've run these tires at the drag strip both times I've gone and at the track when I went to the road course event. The tires looked fine after all of that and I was rotating them after the drag strip and such. Not too long ago, I replaced the worn out outer tie rod ends and have just been daily driving it and now I find this... And unfortunately I'm strapped for cash bad right now and am looking at replacing 2 tires that will not be covered under warranty from Discount Tire + a front end alignment. :( Guess I'll be driving the beater car for a bit...
probably the combination of tie rods being changed. And not set right(just a fraction off and it will do things)
And the autox more the likely messed with the front end. May not seem like it but it beats on the front end. I check and adjust mine few times a year. Because of the abuse the front end sees on track days.
Does that also hold true for aggressive street driving? I like to throw my bitch around in turns kinda hard sometimes lol.
lol yep it will. its a common thing people over look. When you are driving balls to the wall. You need to maintain your engine. And it holds just a true for the suspension.
I follow the motto "Broken engine will ruin your day. Broken suspension will kill you!"
Lol no kidding. Finding that yesterday was a pure fluke, too. I was pissed off from arguing with my wife about some stupid shit and decided to go outside and scrub my calipers clean to blow off some steam and found I was on the verge of 2 blowouts. Guess everything happens for a reason, huh. If it hadn't been for that, I'd have just kept right on driving it till they popped. :lol:
