http://www.racingjunk.com/Complete-R...-RACE-CAR.html
Classifieds ::
Drag Racing Cars
:: Complete Race Cars
1995 Z28 CAMARO TURN KEY RACE CAR
Ad #182164667 Posted:2014-03-23 11:09:23
http://s3.amazonaws.com/s3.racingjun...argephotos.png
http://s3.amazonaws.com/s3.racingjun...-undefined.jpg
http://s3.amazonaws.com/s3.racingjun...Y-RACE-CAR.jpg
This ad expires in 65 days.
$9,900.00
MYSTIC TEAL METALIC; CUSTOM SILVER STRIPE,
FIBERGLASS HOOD with SCOOP,
ALWAYS GARAGED, NO RUST,
NOT STREET LEGAL
CUSTOM ROLL BAR WITH SWING OUT BAR
POWER STEERING,
POWER WINDOWS,
STRANGE MANUAL MASTER CYLINDER,
ATI PROCHARGER PSIC WITH 12 PSI PACKAGE,
HUGE AIR TO AIR INTERCOOLER,
383 LT1 COMPLETELY BUILT UP BLOWER MOTOR WITH MAIN CAP STUDS,
INTERNAL BALANCE ROTATING ASSEMBLY;
PROBE SRP FORGED BLOWER PISTONS, 16CC,
EAGLE FORGED 4340 H BEAM RODS,
EAGLE 4340 FORGED 3.750” STROKE CRANKSHAFT,
CUSTOM ALUMINUM BLOWER HEADS,
CUSTOM GROUND BLOWER CAMSHAFT,
58mm THROTTLE BODY,
FAST 2.0 XFI ECM AND HARNESS
60 LB FUEL INJECTORS,
MSD 6AL IGNITION BOX
MSD BLASTER IGNITION COIL,
MSD 2 STEP REV LIMITER
PACESETTER CERAMIC COATED LONG TUBE HEADERS,
TH350 RACING TRANSMISSION, MANUAL SHIFT, REV PATTERN, TRANSBRAKE
ART CARR 10” 3500 RPM CONVERTER,
B&M RATCHET SHIFTER
EXTERNAL TRANS COOLER,
SFI FLYWHEEL,
MOSER 9” FORD REAR END, 3.70 RATIO WITH POSITRAC,
BMR WELDED FRAME CONNECTORS,
BMR TUBULAR TRAILING ARMS,
BMR ADJUSTABLE TRACK BAR,
BMR ADJUSTABLE TORQUE ARM AND CROSSMEMBER,
ADJUSTABLE DRAG SHOCKS,
DRIVESHAFT HOOP,
NEW ALTIMA BATTERY IN TRUNK,
BATTERY SHUT OFF SWITCH
FRONT BRAKE LINE LOCK,
NEW BF GOODRICH G-FORCE T/A DRAG RADIALS, P 275 /60R15 ON
9”X 15” WELD RACING DRAGLITE WHEELS,
NEW BF GOODRICH 155/80 X 15 TA RADIAL TIRES ON
4”X 15” WELD RACING DRAGLITE WHEELS,
CUSTOM X PIPE WITH DUAL 3“ FLOWMASTER MUFFLERS,
SUPPORTING TECHNICAL INFO; FILES AND RECIEPTS
Seller Phone Number: 203-358-0846
This item is USED
Trades NOT ACCEPTED
Item Location: STAMFORD, CT Get Directions To This City
http://s3.amazonaws.com/s3.racingjun...actSeller2.png
