Maintenance on my '94 z28 pic heavy
Aggh should have bought the smaller headers! Of course everyone else's would hit the steering shaft but not me ;). Need to get this done before it gets to -10 tomorrow. We had an Ice storm so I can't drive now. Should finish up tonight.
If you buy the 1 7/8" headers (I think that's what they are). They require beating on. I had to hammer the right side in 3 different places. The left side drops straight in but hits the steering shaft. I did both of mine from the top.
Had to remove right side 3 times and left side once. Still have it on ramps. It may hit below. Need new motor mounts.
I think plugs are harder to do now. Wires are easier tho. I used to be able to do the front 3 on each side from the top. Hard to get #5,7,8 w/ the headers.
I want to leave a review that says "Perfect fitment. 2 beer job!"
Quote:
Originally Posted by
Stormyweather
Mrmaroon Weren't those Speed engineering headers? Ive been thinking about those but I don't drink.
Yea they were the Speed Engineering. If you buy them get for sure new motor mounts, a hammer, drill the outside holes bigger, get Allen head bolts, put the back bolt in first.
I had a helper and it took me a while to make what I had work. I was in a closed barn most nights it was 20 degrees and no working heater.
I got pissed off one time enough to cut my hand open. This was after it took 3 tries to get the passenger side in from the top. I couldn't get the back bolt in. I pulled it a fourth time and did last bolts first.
Driver side dropped straight in. The problem there was the steering shaft. Denting the tube and moving the steering column over was just enough. I may have to get new mounts.
I'm running open headers until the noise pisses me off enough to do the Y pipe. It looks like Ill have to cut the drivers side pipe to Y and my stock cat back some. Running the Y parts without the collector and angling then outward for now. I only needed 1 O2 extension.
They don't look bad, but they're not Kooks either. If pacesetter had cheap stainless I would have got smaller pipes. I've got a magnaflow to put in next.
I'll post a video and some photos when I'm done cleaning up. The headers look great installed Y pipe looks good too. Car sounds good with open headers was surprised!
If I could go back I would def buy the motor mounts and may still do that.
