Well been working on it a good bit lately car was running pig rich due to a bD coolant temp sensor so got that replaced.
http://i39.tinypic.com/2il0zf6.jpg
Car also was started to start and then suddenly die on me and kept throwing a cam sensor high voltage code tested the connector for ground and power and changed the sensor with no luck. Started to read up on how it could be the cam bolts backing out. So I tired the car down and locktited the bolts. Started to put the pulley on when I noticed I couldn't get the bolt to thread in -_-. Long story short I stripped the crank threads and thought I was about to have to pull the motor ad start over. Thank god for this little guy what a life save lol tapped it and it worked good as new!
http://i43.tinypic.com/idg1le.jpg
