Look into a hipster brake. Griner is real nice but overkill.
Update:
I went with the extreme automatics billet valve body. I now have 5x more in the valve body than the entire transmission. I got an offer on the 88mm that was worth going for. I sold it and bought a borg warner s475. After I swapped it over I decided to switch back to efi, so I went with ms3 pro. Ran that for a while and sold the 355. Ended up buying ryan stouts 383 out of his fox body to run while I looked for a set of heads for my other 383. When I swapped it out I decided to buy a new converter and have it speced for the new setup. I went with a jakes billet triple disc lockup. I've been working on getting the tune right but hopefully will have it lined out before the shootout.
Since I switched from blowthrough to efi I decided to add methanol injection. I'm currently running two 625ml nozzles and thinking of adding another spraying on the inlet of the turbo. So far so good. I like the stuff. Been running 100% meth. Smells amazing. That's all for now
https://uploads.tapatalk-cdn.com/201...86ab8bebbb.jpghttps://uploads.tapatalk-cdn.com/201...8c5f9fc82f.jpg
Damn man... been putting in that work. I wish i had ur ability.
looks awesome !!!
Thanks guys. I'm going to have to stick with this setup for a while. This will be the 4th shootout my car has been to and has had a different setup each year. I can't make any progress on the suspension/weight loss things I should be doing
Well I've fought opti problems for the last time. Had some issues on the dyno and decided I'd had enough. Installed a crank trigger setup and made a cam sync out of the guts of an opti. I still need to finish the wiring and eventually make a more rigid bracket to hold the crank sensor but it runs.
https://uploads.tapatalk-cdn.com/201...63220f33dc.jpghttps://uploads.tapatalk-cdn.com/201...6b5682aca3.jpg
