Not gonna mod the red pill? Leave the supra stock. Dat lt4 doe.....looks awesome
So do i. More because I'd be jealous as hell. One of my first dream cars was a quicksilver metallic supra. A guy down the street had one. To4r turbo, car always sounded amazing. I think he still has it.
@blackbirdws6 idn if I asked, but what plugs are you running? It's a little fat, granted 2nd start and cold, running a bkr6e ngk. https://youtu.be/jPYtNIR-HK8
PARDON MY LANGUAGE AT THE END, it literally scared the shit out of me, I had to wipe. Knocked the snow off the car next to me and my ear was ringing for a solid 5 minutes. This procharger is moving some serious air now, even at idle.
Running br7ef plugs. Sounds good!
Sent from my SM-G935V using Tapatalk
https://uploads.tapatalk-cdn.com/201...d24cfd382e.jpghttps://uploads.tapatalk-cdn.com/201...7fbb5761ab.jpghttps://uploads.tapatalk-cdn.com/201...92929036e6.jpg
Number 2 has calendar submission all over it
Sent from my A621BL using Tapatalk
https://uploads.tapatalk-cdn.com/201...a2133f7fad.jpg
Didn't get to log today, fuel pump relay under dash went bad. Was fun pushing car in garage in 40mph wind with 5 degree wind chill
Man... if it just had 2 tail pipes...
OWNER/ADMIN
Thats cool... or make a big oval tip and center it.
OWNER/ADMIN
Noooooo
Ok so this is fucked up, changed fuel pump relay, car runs for 10 seconds and dies. Did it twice. Then relay doesn't prime fuel pump. Put old relay back in siddenly works then acts up again. Vats light ok, no vats issue that I can see, unless theft deterrent module is fucking up or pcm is screwing up
Got home from the central pa parts run and turned the key twice. Both times it primed.....i am lost lol
I did reflash the pcm to see if that would clear it up, as a failing checksum or something could cause weird issues, and we kept jumping this car with a battery charger when the optima died
Primed, but did it fire and stay runnin?
OWNER/ADMIN
Delete the factory relay.
If you have a hot wire kit it's just something to go wrong
So are you suggesting basically jumping the pcm signal wire to the gray wire that runs back and powers the coils on the other relays? It's the lonnies double pumper setup outback.
I thought about doing that so then the pink power from the theft deterrent relay is no longer in use.
Yup, run a new lead and it's just a signal at this point anyway.
It's running fine now. Fired off quick as hell, I made him go for a ride. He said it's a little scary now, because when the bov closes you better hold on.
had an issue with belt alignment with a.c. delete pulley. fixed that and changed oil. this car is friggin scary fast. went for a ride with the old guy (he was driving), and seriously, when you hit the point the bov closes, hold the hell on
Awesome! So its ready for dyno day?
500whp spinning all over the damn dynohttps://uploads.tapatalk-cdn.com/201...e8db7dbc3a.jpg
https://youtu.be/goSHhHrhSy4
wellllllll. this year made better numbers. 500whp skating on the dyno. peak boost a little over 10psi at 5750 rpm (rpm limiting ourselves). car is a handful on both street and dyno LOL. tune went a little lean, so sent logs to Jeff Creech to see if it's mechanical or tune related (boost was raised almost 4 psig and bigger heads this year). @Ltconvert she's fun!https://uploads.tapatalk-cdn.com/201...f8fd217019.jpghttps://uploads.tapatalk-cdn.com/201...622e8adc4a.jpg
car too fast, scared to drive
