Only place local to do cages quoting me 8 hours at $125/hour to install a cage I bring them!!!
$1k just to install, didn't bother asking what they would charge to build me one after that quote.
Swing outs are not illegal...
Either way, nice bar, my friend has the exact one in his camaro, very nice fit.
So swing outs can be certified?
Awesome... ill def need swing outs when/ if i ever cage anything
From le rule book...
"Swing-out side bar permitted on OEM full-bodied car 8.50 e.t. and slower. The following requirements (a through d) apply:
a. 1 5/8-inch O.D. x .083-inch CM or .118-inch MS minimum. Bolts/pins must be 3/8-inch-diameter steel, minimum and in double shear at both ends.
b. Male or female clevis(es) permitted. Male clevis must use two minimum 1/8-inch-thick brackets (CM or MS) welded to each roll-cage upright; female must use minimum 1/4-inch-thick bracket (CM or MS) welded to each roll-cage upright. Pins must be within 8 inches of the vertical portion of both the forward and main hoops. A half-cup backing device must be welded to the vertical portion of the main hoop (inward side) or the upper end of the swing-out bar (outward side), minimum .118-inch wall (CM or MS) extending at least 1 5/8 inches past the center of the pins. A clevis assembly using a minimum .350-inch-thick male component and two minimum .175-inch-thick female components may use a 1/2-inch-diameter Grade 5 bolt and does not require a half-cup backing device.
c. Sliding sleeves of 1 3/8-inch x .083 CM or .118 MS, with minimum 2-inch engagement, are permitted in lieu of the upper pin/cup.d. All bolt/pin holes in the swing-out bar must have at least one-hole diameter of material around the outside of the hole"
Shoveling... UPS truck pulls up... I pause and slow my breathing, ready to react in between heart beats...
I see him, climbing out of the truck with an F-body rollbar... Then I blink, and it turns into a box with a Disney Frozen bike...
Safety back on, shoveling continued.... Stay tuned.
You would have the coolest roll bar ever if it was Disney frozen themed! :lol:
