We will be standing by for good word tomorrow then!
I'm still missing a power I think. It will fire right up with ether but soon as that burns out it's dead. I don't think the injectors are firing. Is there a wire that feeds the injectors from the pcm?
I think I'm gonna pop the rail up and crank it to see if the injectors are apraying
I checked the PCM grounds on the one plug they were good
I unplugged the maf and it starts!?!?
Check the build page!! I unplugged the maf and it fired right up. I did it two times. But also it cranked 2 or 3 times unsuccessfully. So I'm gonna rewire the blue connectors pink wire. I just had those wire taps and I dot trust those. I'm gonna splice into the wires since it needs the power for sure. I didn't wanna cut into the wires b4 knowing for sure that I needed too. (Just OCD about tht stuff) so why would it start on speed density and not with the maf plugged in?
It's weird, it don't wanna start on it's own but little blast of ether it will fire up and die, then start and stay running. Or it will just kick on and stay on. But I have no oil pressure on the dash. Could be I just missed the sensor for it. Or I'm still missing something. Haven't tried plugging the MAF back in to see if that makes a difference or not. Kinda lost?
