Glock gen 3 are 500 gen 4 are 550. You can find them for 475/530 at gun shows. With the LE pricing they are cheaper
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Man there's too many freakin choices!! This gen that gen!! IT'S OVERWHELMING!!! Lol
For what it's worth I have a gen 4 n wish I got a gen 3 now
Ya fat!
Few things to consider,
If you have kids, a glock may not be your best choice as there's no external safety. If they happen to get their hands on it, that could be a bad thing. Hopefully you wouldn't leave a loaded gun where a kid could access it.
Ammo, if you are buying to target shoot frequently ammo price should play a big roll as prices won't be going down any time soon. It sucks to stop 50-75 on .357 and 45 just in ammo to hit the range for a half hour or so.
If you are buying for home protection, make sure you buy something that your wife/sig other is also comfortable handling. In other words a S&W 500 wouldn't be a good choice if you have a small wife that may need to protect herself.
Sent from my ADR6400L using Tapatalk 2
The Gen 4 has an initially smaller grip than the Gen3, and comes with two different backstraps to adjust the grip to your liking. Most seem to prefer no backstraps. The 1st backstrap makes the grip the same size as a Gen 3 gun and the second one makes it a bit larger. This is the one I actually prefer on my G17 so far.
Next, the recoil spring has gone from a single spring to a dual spring setup to lessen the felt recoil and to reduce stress on the frames in .40 guns and above. Theoretically, Glock .40 pistols were guns adapted from 9mm. Now the theory is the Gen4's were designed more around the .40 cartridge. This originally caused issues with the new 9mm variations of theGen 4's due to the fact that they tried to use the same spring for both, making the 9mm's only truly reliable with the higher energy 9mm rounds out there and made them highly susceptible to limp-wristing.
Another change is the grip surface. It has a new, more aggressive gripping surface to make the guns easier to hold onto with sweaty hands or worse. It works quite well but can be a bit abrasive if you use an IWB holster. I also believe the finger grooves area little less aggressive than the original finger grooves.
Last but not least, Gen4's have a larger mag release that is now also reversible.
Known issues initially with the Gen 4's include, unreliable cycling with the early 9mm's due to being over sprung. Eventually this was fixed by offering a spring exchange program that eventually delivered the proper spring to those affected. Also a problem were bad extractors. this issue was not limited to Gen 4's. It had to do with a design change that was made to both Gen3 and Gen 4 extractors. Don't quite remember what the issue there was.
Dunno? I've always been taught Thats a horrible way to carry though
