Cooling system holds 20psi steady, first bullet dodged.
All cylinders have compression.
Now to toss it back together and weld in second gate.
So, It did blow a head gasket? Going back MLS? Just a curious bench racer.
Nolan
Doesn't seem to have blown a head gasket.
Took the day off so gonna try to get stuff back installed and have the car ready for the weekend perhaps.
Unrelated to the head gasket scare, current wastegate setup seems to want to climb to 9-10psi on gate. Which is annoying since I was able to get 5psi or so on dyno.
So, I said fuck it and ordered another gate before the PRI show
https://i.imgur.com/HVNEUEd.jpg
Another motion part that made me feel dirty to order
https://i.imgur.com/OPWY0aV.jpg
Burnt together
https://i.imgur.com/uM7xQJc.jpg
https://i.imgur.com/Gw2J1zR.jpg
Hopefully I can get 5psi on gate then work on adding boost via on board air
Some random side projects for the car
Sump for a plastic LS1 tank
https://i.imgur.com/xds8GN7l.jpg
Chopped up stock bucket to fit sump and removed the OE fuel pump
https://i.imgur.com/VRZYkKOl.jpg
Fancy sump
https://i.imgur.com/DPNyyTbl.jpg
Dual gates doing work
https://i.imgur.com/hPmSN89l.png
More things to practice aluminum tig welding
https://i.imgur.com/kLgpc57l.jpg
New 100mic pre filter
https://i.imgur.com/GirayYAl.jpg
Big order of txl wire, and DT connectors
https://i.imgur.com/uy4swYPl.jpg
New dial a boost since the last one broke, and the first DT connector to be pinned
https://i.imgur.com/xPirVtNl.jpg
Want an excellent example of what not to do?
https://i.imgur.com/ACABWvNl.jpg
No going back now
https://i.imgur.com/4UdDTFFl.jpg
Oh lawd
https://i.imgur.com/MZSWGWJl.jpg
Spaghetti monster
https://i.imgur.com/CKBgJH6l.jpg
But, hey at least the DT connectors look cool as fuck
https://i.imgur.com/sueqM8Ql.jpg
LAWD, LOL
