It's always been so iffy about who really makes specific brand lifters. In a long ago conversation with Kip Fabre (the owner of Cam Motion in Baton Rouge) he was the one that told me about all the lifter manufacturers going out of business. IIRC it would have been the late '90's or 2000. I was building a BBC and you couldn't find a set of hydraulic lifters anywhere. He tried to talk me into going low lash solid roller because solids were available.
If you want to get the truth about who makes what, he is the man.
According to this Mopar source, the Howards are Morel's ?;
Our Howards Cams Street Series Retrofit Hydraulic roller lifters are 100% USA Made in Cleveland, Ohio by MOREL. Morel started making lifters over 55 years ago for Eaton, and they now operate out of a 100,000 square foot manufacturing plant in Cleveland with over 100 pieces of manufacturing machinery, and they do all their own heat treating in-house, allowing them to maintain full metalurgical control. Sales and engineering for Morel is now handled by John Callies (of Callies Crankshaft fame.) They have grown to become an OEM lifter manufacturer for many other well known brand names such as Howards, Trick Flow, Erson, Lunati, etc. These high performance street lifters are designed primarily for ease of maintenance and reliability. They "drop into" a stock block with no machine work or oil system mods required, and work with all the steel billet hydraulic roller cams we sell, regardless of brand. The lifters have the bodies shaped with cold form technology, then Carbonitrided and tempered for proper hardness and maximum durability. They are then CNC-machined and fitted with precision check ball internal valving to prevent lifter "pump up." The roller wheel is hardened and tempered steel alloy, and the cross bars are made from heat treated stainless. These features combine to provide a broader power band and increased rpm potential, while still offering the low maintenance of a hydraulic cam. These are designed for street performance enthusiasts who want to upgrade to a hydraulic roller camshaft. These retrofit hydraulic roller lifters are specifically designed for street applications up to 6,500 rpm. Roller diameter is .700", and seat height is 2.661"Howards part number 91767.
It appears CamMotion has the 2110's that you spoke of, but the are pricey. What I kind of like about this cam grinder is the don't call them CamMotion lifters, they call them what they are.
https://cammotion.com/lifters/ls-lif...nes-set-of-16/
I have no connection to them other than Kip freely gave me alot of technical help in the past. He's awesome.
Nolan
