That's awesome man! Only takes a gang of people working together to figure out an Engineer's work!
Once it starts, and you get the battery charged. I would make sure there are no draws on the system with that wiring adjustment. Then you should be good for the Shootout.
Timing lights flashing. Almost seems like the injectors aren't firing
I got way more to go b4 the shoot out!!!! Hopefully at least headers and a cam
I missed the comment bout the engineers work! I don't think true words have ever been spoken
I'm ready for a start up video!!! Sounds like you are really close!!
It may fire once the battery charges up some more! Well sounds like it. I just threw test light on the injectors it has a gnd when off and turns off when I turn the key to run. Kinda hard to check it while cranking. Light keeps on popping out.
Attachment 25690This is encouraging!!! I'm getting connection to the PCM! I think just the battery's to low to get her to crank it drops right down to like 6-4-1 lol.
Fingers crossed!!!
I sprayed a tad bit of ether she fired up for a second while the ether burned bu then died pretty quick. I threw the fuel pressure tester on it don't seem like the pump kicks on when it should. Like for priming. Might just be how dead the battery is tho too. I'm gonna let it charge tonite and play in the morning
