And the tires showed up today
https://i.imgur.com/vvKs7iIl.jpg
Along with these guys, which with any luck will be the end of blowing any cold side connections off.
https://i.imgur.com/p5FDtB8l.jpg
Circa 2015 era tires
https://i.imgur.com/eVj0BGnl.jpg
New wheels and tires
https://i.imgur.com/ByALTRXl.jpg
https://i.imgur.com/UYl65Fyl.jpg
#feelingfancy
Officially moved to a house with no garage. :(
https://i.imgur.com/S79BX7Dl.jpg
https://i.imgur.com/P5EfabNl.jpg
But had fun with label maker
https://i.imgur.com/NsKY3mnl.jpg
Not much to update, but, officially PA legit. Been stuck waiting the past two weeks for the classic plates to come in. Hopefully the safety inspection goes well if I do it.
https://scontent.fagc1-2.fna.fbcdn.n...c8&oe=60DA606D
In the never ending ADHD fueled boredom of ruining this car, I present, this, BMW parts!
Pump is a CWA400, which allegedly will flow 58gpm with a 8psi head. Its a hell of a pump compared to the free flow rated 55gpm I have on the motor now.
https://i.imgur.com/Ui3qgq3l.jpg
After verifying pump worked on the bench, roughed it into the car for some trial live running
https://i.imgur.com/WIJqwwQl.jpg
https://i.imgur.com/nttz4T1l.jpg
Currently have no thermostat in the motor and I blocked the bypass port in water pump housing. I will need to now mount the pump for a test drive and fine tuning of the PWM table. Goal is of course to slowly ramp in pump as heat calls for and have it set for a proactive ramp in based off of TPS.
Moral of story, never buy a holley that allows for this sort of behavior.
Was concerned with the height relationship between rad cap and EWP, but so far has proved to be not an issue.
Quick data pull from today's lunch break.
This is the fan settings, so 20% fan speed
https://i.imgur.com/8xtTnmgl.jpg
And the water pump settings, 52% of pump speed.
https://i.imgur.com/aNrXO6Rl.jpg
I did not pick the 168* ECT as a goal, was thinking I would shoot for 180* but, guess this pump moves some water. Previously at a idle warm up, it would run right to full fan settings at 185* area.
So after proving concept to myself, mounted pump down low.
https://i.imgur.com/S1NdR2ol.jpg
Some custom advance auto coolant hose action
https://i.imgur.com/JU79S4Kl.jpg
Hope to drive it tomorrow and verify my duty cycle tables.
No worries, bls hooked me up with a cover
Wife had a day off and took over baby duties, so out to the driveway.
https://i.imgur.com/TZJPWH3l.jpg
Pulled the bumper cover off, and "fixed" the intercooler mount. I had caught something with the lower brackets and it bent the thing inwards towards radiator.
So bent stuff back to where it should be, replaced the 90* aluminum I had as a base with a straight steel piece. (you can see the aluminum on the ground).
The hope is that the opening from air dam is now larger and maybe it runs cooler on highway.
Used some of the radiator fan mounts to mount trans cooler to intercooler.
Also wired in a relay so the low oil sensor will work properly now via Holley dash.
Tmmr is oil change, curious how this stuff works.
https://i.imgur.com/U6KjtoNl.png
